90 Amp Power Supply
- wild willy
- Real Name: Bill
- Antenna: SS Whip, Dipole
- Radio: Many Different
90 Amp Power Supply
I just saw a 45 amp 13.8V power supply that would work for a few different electronic things, on flebay.It looked like it came from a HP computer. It says it will run on 110 or 220. Would these be any good for a small amp? You know the old saying, " If it sounds too goo to be true....." I'd like to get a 90 amp if they are legit. Update: I just learned they are refurbished from a server. Still, I'd like to know if it would work.
Re: 90 Amp Power Supply
I don't have one of them but read the descriptions carefully. Noise is the only problem I see, some switching supplies are very noisy and trying to filter it would increase the cost extremely. The good thing is that they can be siamesed together to make a bigger supply as long as they are the same units. If you get one we would like for you to keep us informed on it's performance.
- wild willy
- Real Name: Bill
Greg, I'm going to order one. I hope I don't waste money doing it. It has a fan & a 3 prong plug. It looks like the plug that you would use to power your CPU. I'll let you know if it's ok when I get it.
- Handle: Spiderleggs
- Real Name: allen
- Antenna: antron
- Radio: various
I've used them out of old computers, I had no extra noise in using them.
- wild willy
- Real Name: Bill
Thanks for the comment. I just ordered mine this evening.Spiderleggs wrote:I've used them out of old computers, I had no extra noise in using them.
My bench power supply is built out of server supplies and no noise on 11 meters. I haven't listened for noise on other bands and mine are dell brand. Over 200 amps for under $100 ain't a bad deal.
- Bluerunner
- Handle: BlueRunner
- Real Name: Mike
- Antenna: Starduster
- Radio: Cobra 142
My experience with using computer power supplies is they put out something like 11.7 to 12.2 VDC which is just fine and in the practical operating range.
However, 14 to 13.8 VDC is what you get from your car / charging system and more like the optimal range. It doesn't matter to me, but someone who is trying to squeeze every milliwatt of performance out of their equipment may be disappointed.
Retail Cb / radio high amp power supplies typically allow you some adjustment and an extra volt or two can noticeably boost the performance of an amp too, at least when splitting hairs on the watt meter.
I know the difference can be insignificant from an operational point of view, but some may feel shortchanged losing a watt or two, even if it lengthens the life of their equipment and leaves some extra money in their pocket.
Computer server power supplies are an excellent bargain for the price and i recommend them too.
- wild willy
- Real Name: Bill
Like stated, I just ordered my 90 amp. If it works out OK I'll order one a bit bigger if needed. Output is stated at 13.8 volts. If you hook it to 220V instead of 110, things start to change from what I read. I'll believe it when I see it. Thanks everyone!
Alot of them are like that. The first one I tried would max out at under 12 volts. The ones I use are at 13.5. There are some that will exceed 16 volts with some modifications. The RC forums have a lot of info on these.Bluerunner wrote:My experience with using computer power supplies is they put out something like 11.7 to 12.2 VDC which is just fine and in the practical operating range.
- wild willy
- Real Name: Bill
Well, it came, 2 hooked together. Each has it's own power chord though. One 13.8 Volt output.
