29LX w/ TNT 600 HD?
Fogdog
Radio: Stryker 955 HP
Antenna: IMAX 2000
29LX w/ TNT 600 HD?
Post by Fogdog » Saturday, 21 July 2018, 5:42 AM
I have a Cobra 29LX and a Xforce TNT 600 HD Amp laying around in the shop. I'm wondering if this combination will work without toasting any parts. I plan on a mobile install. The 29lx is bone stock.
Thanks for any help or advise.
295 antenna
Mod Duck
Mod Duck
Radio: optima ,cobra 148ex
Antenna: patriot,brownig
Cell Phone: 760-672-1257
Re: 29LX w/ TNT 600 HD?
Post by 295 antenna » Saturday, 21 July 2018, 8:24 AM
should be ok do you have a power meter?
TWRC Member : WR2950
Post by MDYoungblood » Saturday, 21 July 2018, 9:09 AM
Well we will say a non modded 29 will do around 4+/- average watts feeding a HD amp the power output will be about 1/4 that of using a HD radio.
Fogdog
Antenna: IMAX 2000
Post by Fogdog » Saturday, 21 July 2018, 9:16 AM
I do have a power meter.
I'm not sure I understand the above post, as far as power output goes. Can I expect a decent increase in power? Any ideas how much?
Post by MDYoungblood » Saturday, 21 July 2018, 9:27 AM
I stated you will see 1/4 of what a HD radio like your Stryker would show so if you gett 600w out of it hooked to the Stryker then expect around 200w out of it with the 29. You will never hurt an amp underdriving it but overdriving will, voltage is just as important as well, so is amerage.
Fogdog
Antenna: IMAX 2000
Post by Fogdog » Saturday, 21 July 2018, 9:29 AM
I got it. So if my Stryker 955 did 800-1000 Watts, the 29lx would do maybe 200 watts out?
Wonder if I'd be better off just connecting the little Shooting Star 225 amp to it. Hmmmm!
Post by MDYoungblood » Saturday, 21 July 2018, 10:56 AM
I wouldn't run the amp that hot, it won't take the abuse. Those amp's with the "HD" designation means it can be driven with a radio doing 30/40 watts (the "HD" mosfet amps are even less input wattage), not 75/80. Hook it up and adjust the DK to around 150w and let it swing. The 29 hooked up the DK might be around 60/75w. Should see loads of swing if the modulation is right.
Fogdog
Antenna: IMAX 2000
Post by Fogdog » Saturday, 21 July 2018, 15:49 PM
Thanks for the help.
