PA sound
rubberboot
Cell Phone: 7073866433
PA sound
Post by rubberboot » Tuesday, 28 November 2017, 16:16 PM
Hi there, I have a cobra 29 wx nw st and I was wondering if it's normal that when you switch to PA , the CB audio comes out the PA speaker. I am trying to determine if there is a problem with this rig.
Thanks for the help.
Pierre
Logged in via: iPhone
Re: PA sound
Post by MDYoungblood » Wednesday, 29 November 2017, 11:38 AM
Hello rubberboot,
Welcome to the forum. Usually it doesn't, switching to PA should disconnect the receive section in the radio but there are some older radios that do. Does your radio have a talkback feature or someone installed the resistor mod to get talkback in the radio,, in that case yes you will hear the receive when the PA is turned on.
As a new member could you post an intro in the "Welcome to the Forum" topic, viewforum.php?f=89 , so others here can say "Hi", thanks.
Re: PA sound
Post by jessejamesdallas » Wednesday, 29 November 2017, 18:33 PM
Sounds like you got a hacked-up radio...
443 Arizona
Radio: madison on 5/8 wave
Re: PA sound
Post by 443 Arizona » Wednesday, 29 November 2017, 20:37 PM
sometimes guys would wire it like that so they could be out away from the vehicle but still monitor the CB.
Re: PA sound
Post by jessejamesdallas » Thursday, 30 November 2017, 4:20 AM
It may have been wired so if you were using a external speaker plugged into the PA, you would have "talk-Back"...Just need to reverse the mod.
This may help.
http://cbradiomagazine.com/April%202007 ... 0radio.htm
Users browsing this forum: Google [Bot] and 1 guest
