Galaxy 55hp
- Handle: bandit
- Real Name: Drew
- Antenna: A 99
- Radio: Galaxy 99 v
Galaxy 55hp
I have a galaxy 55hp the guy told me he dropped the frequency counter want change when you turn the channel selecter knob but the channel display will change thank you
[ Post made via Android ]
Re: Galaxy 55hp
What frequency is displayed on the counter?
- Handle: bandit
- Real Name: Drew
- Antenna: A 99
Re: Galaxy 55hp
10.695 That what the Frequency counter reads
Re: Galaxy 55hp
Okay, that is the mixer frequency, first check all the plugs to the main board to see if they are plugged in tight and the right way, if good then it's searching for a cold solder joint or broken trace, possibly the board cracked as well. Is the radio transmitting and receiving fine?
- Handle: bandit
- Real Name: Drew
- Antenna: A 99
Re: Galaxy 55hp
it will transisment about 20 watts but you can hear a bunch of noise thats it
- Handle: bandit
- Real Name: Drew
- Antenna: A 99
Re: Galaxy 55hp
it will work good for just a few minutes
Re: Galaxy 55hp
I had one to do the same thing. look for a solder joint tha could be crossed or one that's not sordered good
