What causes frequency bleed over
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
- Antenna: A99/Wire dipole
- Radio: Anytone AT 6666/Bearcat 980SSB
Reading about frequency bleed over. What would make a radio bleed from 27.025 to 21.965. Reading about one dude that had a radio which did that and got in trouble.
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
- jon6667
- Real Name: jon
- Antenna: dipole
- Radio: icom 7300
Re: What causes frequency bleed over
a dirty class c amp.
That and probably lived in close proximity.
Was this the CB'er bleeding on a Fire Department band up in Alaska?
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
his radio was bleeding into air line emergency channels
Can I get examples of "dirty class c amps"?
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
- jessejamesdallas
Heck, just pick one...If it cost under $1K, it's probably a dirty C Class.
Bigger problem than Amp's, is radios that have been Peaked & Tweaked with coils inside spread as far apart as you can get them without popping off the board...Take that radio and stick a Amp behind it, and you can talk on all 40 channels at the same time!
Google pictures of amplifiers and look at the difference between amateur amps and amps built for CB.
Class of operation has nothing to do with this. A class ab amp can break into oscillation and trash the band too. If the amp isn't oscillating I'd test the transmitter next. It's likely an export, had some crazy channel mods done or just a good overall hack job.
"...good overall hack job."? An oxymoron if I've ever heard one.543FtWorth wrote: ↑March 18th, 2017, 6:52 amClass of operation has nothing to do with this. A class ab amp can break into oscillation and trash the band too. If the amp isn't oscillating I'd test the transmitter next. It's likely an export, had some crazy channel mods done or just a good overall hack job.
