Need help with CB Squeal....
- kidx
- Real Name: Ron
- Antenna: Uniden PC787
I am getting a high pitch squeal on certain channels, Only when people key up like 16 and 4. I am only hearing it when certain people key up, I am running a Uniden PC68LTD 50th Anniversary Limited Edition. Also I have SR-A10 Stryker antenna and its amazing so fare. I also have a lowpass filter that I cannot remove due to the Sodial ends are not here coming from Hong Kong.
- 443 Arizona
- Mod Duck
- Handle: Double R
- Real Name: Steve
- Radio: madison on 5/8 wave
Re: Need help with CB Squeal....
its important that you ask yourself,,,,do you have good grounding?
are you too close to the other radio's? are they amped radios? are you sure its "other radios" and not something else. can you squelch/NoiseBlank it out?
if you are sure of the problem then take it to a technician.
- 295 antenna
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
Im with 443 Arizona , make sure have good grounding .I know i have a 959 i use for a base and if im not grounding when i run power i get a squeal. Now also make sure its not feedback from another radio or external speaker.
You are only hearing this squeal on those channels? I'll say it is the close proximity of the transmitting radio. Being a AM radio it is heterodyne, not really a squeal. What is the SWR of the antenna system your using? Why are you using a low pass filter?
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
since you only get the noise from another radio keying up I would not think it is your radio as far as grounding on your end. how close are the other radios from you and does it do this from all people keying on these channels. some thing does not make a lot of since . if they are close to you it could be over driving your radio if they are close to you.
- kidx
- Real Name: Ron
My swr is 1.5, Also reason for lowpass filter is due to interference. I cannot do anything till I get my sodial ends. Also Class C amplifiers are know to cause this on cb radios, I hear like a heterodyne sound on certain channels.
What is a "sodial end" ? Inquisitive minds would like to know.
- jessejamesdallas
I was wondering the same thing!MDYoungblood wrote:What is a "sodial end" ? Inquisitive minds would like to know.
- dgbacb4148
- Real Name: David g.
- Antenna: shakespere Big Stick
- Radio: Uniden Washington
Ron, from your statement................... Only when people key up like 16 and 4, ..........,are you sure your not hearing their equipment squeal ? I'm confused. JMHO and good luck.
David g............
David g............
- kidx
- Real Name: Ron
Well maybe it was that box, Here is what sodial ends are. Also on my Nessie metter the swr is like 5/6 and we put it at ever length holy nothing no result not much I am still testing. The issue could be power supply as well i dont know i might take the advise on a better power supply what is a good power supply you can recon mend thats easy to set for noobies?
psc=1
psc=1
Okay, "Sodial" is the manufacturer that makes a "barrel connector", that is what we call them. Next time use a pic instead of a **Non Sponsor** link. Don't worry I fixed your post.
- kidx
- Real Name: Ron
Yes i might get a new power supply, This may fix my SWR and preformance.
- Stoneman
- Handle: Stoneman
- Real Name: Junior
- Antenna: One Shot Dipole
- Radio: Cobra 2000 GTL
I never had much luck with those barrel connectors...I'd get different reading every time..
