9 volt battery get's hot
d-minus
Radio: cobra 29ltd
Post by d-minus » Tuesday, 07 February 2017, 22:43 PM
O.K. i wanted to install a prewired led in my radio shack meter so i got a 9v battery a hard shell top lead for battery at radio shack and got a green led (just to try it) out of my parts shelf until i could get a white one. Also got a miniture toggle switch from radio shack,now i put the black leads together and the red leads together from the led and the battery. And soldered them to the switchIt works BUT, if i leave the top cap on the battery it will get hot ,so i take the cap off the battery let it cool 30 minutes put it back on leave it for hours and it will not get hot. Same thing goes if i turn on the led. Connections are not touching.Switch is a spst 3amp rating at 250v 6 amp at 120v. Also tried flip flopping wires on switch still the same. What's up with this. I have hooked other things up like this with no problem. I don't understand. Thanks for any help. Daniel
pabxone
Radio: NDI PC201
Antenna: 1/2 wave vertical
Re: 9 volt battery get's hot
Post by pabxone » Wednesday, 08 February 2017, 5:38 AM
Have you put a resistor in series with 1 lead of the LED ?
LEDs need a dropping resistor if being powered by anything over 2 volts.
For 9 Volts you need a 330 Ohm 1/4 resistor to work correctly.
Here's a good primer on powering LEDs :- http://www.evilmadscientist.com/2012/re ... -for-leds/" onclick="window.open(this.href);return false;
d-minus
Radio: cobra 29ltd
Post by d-minus » Wednesday, 08 February 2017, 9:19 AM
Yes they have a resistor, they came prewired with it. I hooked it back up this morning a 9:00 but it has not got hot yet. this is the problem it might get hot then it might not. Thanks. Daniel
Post by jessejamesdallas » Wednesday, 08 February 2017, 10:37 AM
d-minus wrote:Yes they have a resistor, they came prewired with it. I hooked it back up this morning a 9:00 but it has not got hot yet. this is the problem it might get hot then it might not. Thanks. Daniel
Samsung battery? :shock:
d-minus
Radio: cobra 29ltd
Post by d-minus » Wednesday, 08 February 2017, 11:03 AM
JJD, Energizer industrial. (did not have a duracell) Daniel
420Snowman
Radio: Snowman Built 29
Antenna: Shockwave
Post by 420Snowman » Saturday, 11 February 2017, 6:10 AM
Hmmmmm, this is strange. Why would it intermittently get warm then other times not..... Hmmmmm
Rolling the Snowman Built Gateway Mobile
16 pill Snowman Built
Snowman Built Cobra 29 LX
Davemade coil stabbed in the roof
d-minus
Radio: cobra 29ltd
Post by d-minus » Monday, 13 February 2017, 22:19 PM
Well , it was the mini switch. changed it out to a 12v rocker switch for car rated for 10 amps. problem solved. Mini switch was rated for 125v,1.5 amp. I don't understand it but that took care of it. D-minus
Post by sonoma » Tuesday, 14 February 2017, 3:19 AM
good deal. some times some thing just does not work well in a application.
Post by MDYoungblood » Wednesday, 15 February 2017, 12:41 PM
You should check out some of the 9v battery YouTube's, a couple of them are amazing watching how easy it is to heat them up to melting temperature.
Base
Uniden Washington
Mobile
Texas Ranger TR-696FD1C
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
Homemade Full Wave Loop
Homemade 1/2 wave Dipole
d-minus
Radio: cobra 29ltd
Post by d-minus » Wednesday, 15 February 2017, 19:56 PM
Thanks, i'll check them out. D-minus
Users browsing this forum: No registered users and 9 guests
