low pass filter
- 295 antenna
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
low pass filter
With today's electronic is a low pass filter necessary ? i installed one but as i was reading some info online i came across a discussion regarding low pass filters and that they are not needed anymore or maybe just on older equipment ?
Charles (Chuck)
Charles (Chuck)
Re: low pass filter
I still use one, I have a radio that would knock out my DSL router, the radio doesn't interfere with anything else, using the low pass filter stopped that from happening. I tried other things first, the snap beads, a coaxial choke, etc.
Re: low pass filter
It never hurts. I don't use them for my mobile but on the base I have one after the radio and after my 2 pill driver. A good tube amp doesn't so much need one but a filter is a good idea for a transistor amplifier. A few have a built in low pass filter but most don't.
You never know what kind of crap appliances the neighbors down the street have so I make every effort I can to stay clean.
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
- Antenna: A99/Wire dipole
- Radio: Anytone AT 6666/Bearcat 980SSB
Re: low pass filter
haven't gotten any complaints yet, but after reading about low pass filters I guess I'm going to install one just to keep the peace
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Re: low pass filter
Guys that don't like them will say they have lower wattage with the filter installed. If your signal is clean to begin with you may not see any change in output.
- 295 antenna
- Moderator
Re: low pass filter
Thanks guys .I installed on because like what was said earlier you dont know what the neighbors are using and i was also worried about my computer and modem .I was knocking out my external hard drive but not now
- KP68
- Handle: KP68
- Real Name: Ken
- Antenna: Maco M105C Mr Coily 80meter sky loop
- Radio: Apache Labs ANAN 7000DLE MKii
Re: low pass filter
I have one in line after my drivers and before my final tube amp. I'm still getting settled in at my new station location but when I do get all settled in, I'll also have one installed after the final. No complaints from any neighbors and I do not cause any disruptions/interference with my household electronics and I want to keep it that way. Most important is how you run your station to begin with. Keep it clean and mean.
- Mtn Lynx
- Handle: Lightning
- Real Name: Cletus
- Call Sign: WR223
Re: low pass filter
Is the Paradynamics 1089 rated at 1000 watts any good? I read about it, as long as it is grounded I guess it's not a bad low pass filter.
\m/ >.< \m/
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
Anytone AT 6666
Galaxy DX 959
Galaxy DX 2517
Cobra 148 GTL
1/2 wave Dipole
Solarcon A99
TWRC Member: WR223
- jessejamesdallas
Re: low pass filter
Had a problem pop-up couple weeks ago with my daughters headphones...When running my little tube amp she could hear me a little. So got out my trusty old MFJ low pass filter and hooked it up, and no change at all. Then tried my RL Drake low pass filter, and still no change.
Got a ferrite choke and snapped it on the headphone cord, and no more problem...
I don't put allot of stock in those low pass filters. specially running a Amp.
Re: low pass filter
You should be fine with the paradynamics brand. They have been around. My rule of thumb is use a filter rated for twice the power I'll put through it. No worries about running a ground wire to it. Use a double male pl259 and put it on the back of the transmitter. If you have to use coax keep it very short. Inches. You can find some higher end Drake or bencher filters and rf limited used to make a 3kw filter. I have a couple of the rf limited filters. Not saying they will work any better than the paradynamics.
The headphone issue probably wasn't because of harmonics. Your tube amp should be pretty clean because of the pi network you tune it with. The exception is those amps that have 6 or 8 final tubes in parallel. More tubes = lower plate impedance and the closer it becomes to 50 ohms the less effective your tank circuit is as a filter.
If the amp is overdriven, mistuned or the radio is super trucker tuned the IMD goes through the roof and a low pass filter will not help with that. If you buy a used filter it never hurts to open it up and test the caps. The last owner may have burned it up and you'll never know. It just won't filter.
- Blue Ox2
- Handle: Blue Ox
- Real Name: Mike
- Call Sign: KC3LAV
- Antenna: DR-Dipole, Copper "J"-Pole, IMax 2000, MFJ 1740, and a "Slinky" 40M dipole
- Radio: President McKinley&Washington+142GTL Direct Injected by Leadfoot Labs
Re: low pass filter
GOOD info. I'll be adding some ferrite cores around my wife's stuff and I have a low pass filter I'll put in line with the amp when that project is better suited.
How do you do from Blue Ox2
KPA223 on the Galaxy DX 2517
- Handle: Rick
- Real Name: Rick
- Radio: Galaxy
Re: low pass filter
So does the filter go after the radio before everything else or after everything before the antenna lead?
- 295 antenna
- Moderator
Re: low pass filter
It should go after the radio or amplifier. Make sure of the watt rating
