President Base -Squealer
eddieb1965
Cell Phone: 217-371-9418
Post by eddieb1965 » Wednesday, 13 March 2013, 15:49 PM
Just bought a President Zachary T. base for 20.00 It doesnt have the stock mic but it has upper and lower channels added where the phones jack used to be.It recieves great,but on transmit it has the weirdest squeal I have ever heard.I have tried another mic and played with mic gain, but its still there.You can hear the squeal in the radio and the transmitted squeal is 10 times worse,It will get a radio check a couple miles away though.I have an older tech close by,but not to sure of his work anymore.Does it sound simple to anyone?Did someone mess it up by putting in the extra channels? If anybody has any input, it would be great. Thanks Eddie
Re: Predident Base -Squealer
Post by MDYoungblood » Wednesday, 13 March 2013, 22:16 PM
You might open the case and look to see if the old phone jack is shorting out the mic jack (some just tape them up and leave them inside), could of bounced around inside in transit. Did you check to make sure the mics that you tried were wire right for the radio?
Base
Uniden Washington
Mobile
Texas Ranger TR-696FD1C
Handheld
Maxon HCB-40WX
Antennas
Avanti Sigma II
Homemade Full Wave Loop
Homemade 1/2 wave Dipole
Radio: Uniden/Icom/Cobra
Post by 231 » Wednesday, 13 March 2013, 23:45 PM
Mics that aren't wired properly can squeal too. Make sure your mic is wired properly. If it's a power mic, there is a battery in the mic...put a new one in and make sure it's turned down to maybe 30% for starters. Power mic batteries can often causes a squeal too if the battery isn't in perfect shape (especially D104's). Just a few ideas.
Good luck.
231
eddieb1965
Post by eddieb1965 » Thursday, 14 March 2013, 5:35 AM
Will look inside today and look around for shorts.I tried a 4 pin mic off my Texas Ranger TRP Freedom model,would it be wired the same or is the president different? Thanks for the suggestions.
Rabbit Ears
Radio: President HR2600
Antenna: Sirio 27 tornado
Home Phone: 307-674-1541
Post by Rabbit Ears » Thursday, 14 March 2013, 5:50 AM
The President Zachary T. as I remember, has a four-pin mic plugin. (it is a COBRA pinout). So try a good mic that fits a Cobra.
Read the Constitution.
FREEDOM and USA FOREVER
STAND UP FOR THE FLAG!!!
President Grant DX four button (1983 model) PC-999 *in my truck*
President HR2600 (PRIMARY BASE)
President HR2510 (backup base) *solar powered*
K40 magmount
Microphones: Turner +3 *two of them* Turner Super Side Kick
Palomar TX-150 amp
RM Italy KL300P (A/B modded)
BIRD 43P
Sirio Tornado 27 5/8 wave antenna
eddieb1965
Re: President Base -Squealer
Post by eddieb1965 » Friday, 15 March 2013, 14:55 PM
I looked inside and found the phones jack taped up.It looked ok and wasnt shorting to anything.I will try a different mic than the ones I have now.It came with some no name power mic and I just tried my Texas Ranger mic that is a 4 pin also.If I turn the mic gain most all the way down I dont hear the squeal,I need to verify this isnt transmitting with my other radio.I will report what I find either with the mic or by taking it to someone. Thanks Eddie
Wednesday, 20 March 2013, 10:57 AM
I ended up taking it to the local tech,here is what he found.The RF voltage was 15.8 volts(he told me some of the internals were only good for max16 v),he turned it down.He also said a couple of cans were way out of adjustment(bad tune or alignment).It will still squeal a little with the mic gain up all the way and the amp mic over 4. I have it set with the mic gain at 3/4 and the mic at 3 on the mic itself.The tech is an older gentleman who does this for a living,but I dont think he will be able to do it much longer.He also only charged me 35.00. This turned out to be an excellent base radio for 55.00 total and not a scratch on it.Eddie
